Proth7
    3
O Proth7
  1. Rozwiązanie problemu z : Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'. Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 1000 kHz adapter_nsrst_delay: 100 srst_only separate srst_nogate srst_open_drain connect_assert_srst srst_only separate srst_nogate srst_open_drain connect_assert_srst Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : clock speed 950 kHz Error: libusb_open() failed with LIBUSB_ERROR_ACCESS Error: open failed in procedure 'program' in procedure 'init' called at file "embedded:startup.tcl", line 473 in procedure 'ocd_bouncer' ** OpenOCD init failed ** shutdown command invoked Dla mnie zadziałało zainstalowanie st link utility. Z początku nie odnajdwało urządzenia ale po odłączeniu mikrokontrolera i ponownym użyciu i upgrade'u przez st-link utility wszystko zaczęło działać.
  2. Dzięki, już wszystko ok. Mała głupota xd... Save Nie łapię tylko tego : Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'. Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 1000 kHz adapter_nsrst_delay: 100 srst_only separate srst_nogate srst_open_drain connect_assert_srst srst_only separate srst_nogate srst_open_drain connect_assert_srst Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : clock speed 950 kHz Error: libusb_open() failed with LIBUSB_ERROR_ACCESS Error: open failed in procedure 'program' in procedure 'init' called at file "embedded:startup.tcl", line 473 in procedure 'ocd_bouncer' ** OpenOCD init failed ** shutdown command invoked Szukam na forum odpowiedzi, ale coś nie mogę znaleźć Edit. Jeśli dobrze rozumiem przy użyciu st link utility powinno mi pokazać dostępny mikrokontroler? No ST-Link detected... Edit Edit. Ponowne podłączenie i włączenie stlinka zadziałało. Upgrade zrobiłem. Można usunąć post
  3. Hej. Zakupiłem Wasz kurs STM32. Zaktualizowałem sterowniki do stm, korzystam z tego co opisane jest w kursie, ale kiedy daje build wyskakuje fatal error: stm32f1xx_nucleo.h: No such file or directory Wcześniej było z to samo z #include "stm32f10x.h" to na siłę wkleiłem do tego samego folderu i przestało ... W czym jest problem? Jestem w tym nieco zielony i staram się ogarnąć krok po kroku. Wcześniej próbowałem i nie było z tym problemu. Z góry dzięki za odpowiedź. __________ Komentarz dodany przez: Treker
