Blank
O Blank
  1. Witam! Mam problem z tym projektem ponieważ mam podpięte wszystkie kabelki prawidłowo program i biblioteki również a działa tylko sensor (wykrywa ruch) i servomotor ("kręci tylko głową")a nie wysyła żadnego sygnału do silników. Proszę o pomoc! (Film na którym się wzorowałem https://www.youtube.com/watch?v=4CFO0MiSlM8 ) <---SCHEMAT #include <Servo.h> //Servo motor library. This is standard library #include <NewPing.h> //Ultrasonic sensor function library. You must install this library //our L298N control pins const int LeftMotorForward = 5; const int LeftMotorBackward = 4; const int RightMotorForward = 3; const int RightMotorBackward = 2; //sensor pins #define trig_pin A1 //analog input 1 #define echo_pin A2 //analog input 2 #define maximum_distance 200 boolean goesForward = false; int distance = 100; NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function Servo servo_motor; //our servo name void setup(){ pinMode(RightMotorForward, OUTPUT); pinMode(LeftMotorForward, OUTPUT); pinMode(LeftMotorBackward, OUTPUT); pinMode(RightMotorBackward, OUTPUT); servo_motor.attach(11); //our servo pin servo_motor.write(90); delay(2000); distance = readPing(); delay(100); distance = readPing(); delay(100); distance = readPing(); delay(100); distance = readPing(); delay(100); } void loop(){ int distanceRight = 0; int distanceLeft = 0; delay(50); if (distance <= 20){ moveStop(); delay(300); moveBackward(); delay(400); moveStop(); delay(300); distanceRight = lookRight(); delay(300); distanceLeft = lookLeft(); delay(300); if (distance >= distanceLeft){ turnRight(); moveStop(); } else{ turnLeft(); moveStop(); } } else{ moveForward(); } distance = readPing(); } int lookRight(){ servo_motor.write(10); delay(500); int distance = readPing(); delay(100); servo_motor.write(90); return distance; } int lookLeft(){ servo_motor.write(170); delay(500); int distance = readPing(); delay(100); servo_motor.write(90); return distance; delay(100); } int readPing(){ delay(70); int cm = sonar.ping_cm(); if (cm==0){ cm=250; } return cm; } void moveStop(){ digitalWrite(RightMotorForward, LOW); digitalWrite(LeftMotorForward, LOW); digitalWrite(RightMotorBackward, LOW); digitalWrite(LeftMotorBackward, LOW); } void moveForward(){ if(!goesForward){ goesForward=true; digitalWrite(LeftMotorForward, HIGH); digitalWrite(RightMotorForward, HIGH); digitalWrite(LeftMotorBackward, LOW); digitalWrite(RightMotorBackward, LOW); } } void moveBackward(){ goesForward=false; digitalWrite(LeftMotorBackward, HIGH); digitalWrite(RightMotorBackward, HIGH); digitalWrite(LeftMotorForward, LOW); digitalWrite(RightMotorForward, LOW); } void turnRight(){ digitalWrite(LeftMotorForward, HIGH); digitalWrite(RightMotorBackward, HIGH); digitalWrite(LeftMotorBackward, LOW); digitalWrite(RightMotorForward, LOW); delay(500); digitalWrite(LeftMotorForward, HIGH); digitalWrite(RightMotorForward, HIGH); digitalWrite(LeftMotorBackward, LOW); digitalWrite(RightMotorBackward, LOW); } void turnLeft(){ digitalWrite(LeftMotorBackward, HIGH); digitalWrite(RightMotorForward, HIGH); digitalWrite(LeftMotorForward, LOW); digitalWrite(RightMotorBackward, LOW); delay(500); digitalWrite(LeftMotorForward, HIGH); digitalWrite(RightMotorForward, HIGH); digitalWrite(LeftMotorBackward, LOW); digitalWrite(RightMotorBackward, LOW); } Filmik jak działa.rar
