Pokazywanie wyników dla tagów 'moduł'.
Znaleziono 5 wyników
Sprzedam Sprzedam Bluetooth module Telit Bluemod+S42
auristel19 opublikował temat w Sprzedam/Kupię/Zamienię/Praca
cześć mamy do sprzedania moduł "Bluetooth module Telit Bluemod+S42" - wystawiamy FV Product condition: New - Packed (hermetically) on rolls of 1000 pieces Minimum quantity to sell: 2000pcsV The maximum quantity (available): 11,000 pcs. Cost for 1 pcs: 2,9 eur Delivery cost depends of ordered items General info: Bluetooth 4.2 Low Energy plug-and-play module The BlueMod+S42 is a high-performance Bluetooth 4.2 qualified single mode module. It features very low energy consumption and flexibility for designers such as Terminal I/O profile for serial cable replacement use cases as well as most GATT based Bluetooth profiles through a generic GATT implementation. Part of the BlueMod+Sx family, the BlueMod+S42 is swappable with previous generations without requiring new hardware or software spins. Although a single mode low energy module it offers a high throughput of up to 470kbit/s using Telit’s unique SPP like Terminal I/O service. Development Kit Telit’s BlueDev+S42 developer kits enables rapid prototyping of customer’s own firmware: solutions are based on a simple and powerful scripting language, Lua, supported by Telit Appzone development environment or using silicon vendor SDK for C++ development. Evaluation Kit The evaluation kits BlueEva+S42 are available to support Telit customers to evaluate and implement Bluetooth modules in their application. For each of the different FW Versions a separate Evaluation Kit is available. Key Features: BlueMod+S42 Standalone IOT platform or Bluetooth hosted applications Bluetooth v4.2 qualified module RED, FCC, IC, KC, MIC, RCM, Anatel certified Powerful Cortex M4F MCU Designed for low power applications Best of its class range performance Best of its class throughput performance Generic GATT Client or Server Implementation Point to point or point to multipoint communications Terminal I/O Profile (SPP-like) for fast and easy transparent data transfer Automation I/O Profile for digital and analog status information transfer Terminal I/O and Automation I/O Sample code for iOS and Android NFC Support for secure simple pairing LE Secure Connection with 128bit AES encryption -
W moim autku na BT koła miały problem z rozkręcaniem się najprawdopodobniej przez niecałkowite otwarcie się MOSFET-u, gdyż silniczki w aucie są na max. 6 v a układ sterujący na 12 v (jak mi zasugerował stary gracz w tym temacie) i powiedział też, żebym zastosował logikę ujemną, lub sterowanie masą jak kto woli, no i zabieram się do tego i tu jest problem, bo jak na pojedynczych komponentach wiem co robić, tak tutaj nie wiem, od czego zacząć, a nie chciałbym sobie usmażyć czegoś, także co zrobić? Będę wdzięczny za każdą sugestię i odpowiedź
Dzień dobry. Mam problem z tym elementem na górnej (jak się patrzy jak na zdjęcie jest pokazane)takie coś i nie wiem co to jest, i jeszcze dodam, że mam w sumie 3 moduły i na dwóch jest po 1 takim czymś a na jednym, są dwa. PS na necie nikt tego nie ma. Moje moduły nie działają nawet na programach z neta, ale jest jeszcze możliwość złego podłączenia dziękuje za odp z góry
Dzień dobry cześć wszystkim. Planuję wzmocnić sygnał mojej bezprzewodowej echosondy ktora będzie pływać na łodce radio control . Jest plan aby echosonda łączyła się z malinką poprzez wifi co znacznie zwiększy jej zasięg. Malina sama w sobie ma zbyt mały zasięg chodzi mi o minimum 300 metrów dlatego tylko wchodzi w grę dołożenie do niej antenty 2,4 ghz konkretnie modułowej na 5v bo tyle mają moje akumulatory pakietowe i na tyle działa malina. Nie chce żadnych konwerterów, ponieważ wszytsko razem i tak już będzie ważyć sporo a to znacznie obniży ładowność łódki. Przekonałem cały internet i fora ale nie znalazłem informacji jak to skonfigurować a co ciekawsze żadnej antenty na 5 v która będzie miała na jednym kablu wejscie zasilania oraz będzie można do niej podlaczyc sygnał wifi który będzie nadawać. Widziałem że to da się zrobić ale owy Pan chce za samą usługę 800 zł trochę zbyt dużo jak na takie urządzenie. Załączam zdjęcie jak owy zestaw wygląda. Proszę o jakieś wskazówki albo gdzie ewentualnie mógłbym zacząć szukać, jakieś hasztagi konkretne, może źle szukam.
Witam, mam problem z modułem bluetooth, którego potrzebuje do projektu DIY. Wszystko normalnie działało na baudzie 9600 i wprowadzałem komendy w arduino IDE. Po wpisaniu komendy AT+RESET, której zadaniem jest reset modułu straciłem jakąkolwiek możliwość dalszej komunikacji z modułem. Dioda wskazująca na oczekiwanie parowania miga tak jak wczesniej ale nie jestem wstanie się sparować a po wpisywaniu jakikolwiek komend nie dostaje żadnej odpowiedzi. Wbudowany guzik też nie reaguje, nie wiem juz co robic :(
