Arduino MEGA i BLYNK, LCD odchodzi do lamusa...
192.168.254.111 - - [01/Feb/2019:09:28:26 +0000] "GET /index1.html HTTP/1.1" 200 1706 "-" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:28:26 +0000] "GET /style.css HTTP/1.1" 200 1080 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:28:26 +0000] "GET /jquery-3.3.1.min.js HTTP/1.1" 200 30664 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:28:26 +0000] "GET /white-waves.png HTTP/1.1" 200 34945 "http://192.168.254.100/style.css" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:28:26 +0000] "GET /smog.jpg HTTP/1.1" 200 75619 "http://192.168.254.100/style.css" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:28:26 +0000] "GET /kraj.jpg HTTP/1.1" 200 175960 "http://192.168.254.100/style.css" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:28:27 +0000] "GET /favicon.ico HTTP/1.1" 404 510 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:30:06 +0000] "GET /index1.html HTTP/1.1" 200 1706 "-" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:30:34 +0000] "GET /getData.php?nazwa=tempSlonce&mian=%20*C HTTP/1.1" 500 187 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:30:35 +0000] "GET /getData.php?nazwa=tempGrunt&mian=%20*C HTTP/1.1" 500 187 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:30:36 +0000] "GET /getData.php?nazwa=pm1&mian=%C2%B5g%2Fm%C2%B3 HTTP/1.1" 200 216 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:30:37 +0000] "GET /getData.php?nazwa=pm2&mian=%C2%B5g%2Fm%C2%B3 HTTP/1.1" 200 215 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
192.168.254.111 - - [01/Feb/2019:09:30:39 +0000] "GET /getData.php?nazwa=pm10&mian=%C2%B5g%2Fm%C2%B3 HTTP/1.1" 200 215 "http://192.168.254.100/index1.html" "Mozilla/5.0 (Linux; Android 8.1.0; SNE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.99 Mobile Safari/537.36"
Widzisz tu coś?
Widzę - np. getData.php zwraca błąd 500 jeśli zapytasz o tempSlonce... ale to nie o to chodzi.
Pytanie czy na pewno ścieżka w konfigu Apacza zgadza się z tym co robisz (tzn. czy na pewno to /home/pi/html)?
bo jescze nie mam query do tabeli mega, nawet mega jeszcze nie wysyła nic...
plik który zmodyfikowałem wg. Twoich wskazowek:
<VirtualHost *:80>
        # The ServerName directive sets the request scheme, hostname and port t$
        # the server uses to identify itself. This is used when creating
        # redirection URLs. In the context of virtual hosts, the ServerName
        # specifies what hostname must appear in the request's Host: header to
        # match this virtual host. For the default virtual host (this file) this
        # value is not decisive as it is used as a last resort host regardless.
        # However, you must set it for any further virtual host explicitly.
        #ServerName www.example.com
        ServerAdmin webmaster@localhost
     DocumentRoot /home/pi/html
        <Directory /home/pi/html>
                AllowOverride all
                Require all granted
        </Directory>
                               [ Read 38 lines ]
^G Get Help  ^O Write Out ^W Where Is  ^K Cut Text  ^J Justify   ^C Cur Pos
^X Exit      ^R Read File ^\ Replace   ^U Uncut Text^T To Spell  ^_ Go To Line
Edytowano przez SOYER
No ten plik jest w porządku... ja mam zresztą identycznie u siebie na malince i wszystko pięknie mi czyta z ~pi/html - błąd musi być gdzieś w innym miejscu. Na wszelki wypadek pokaż wynik:
apachectl -S
pi@raspberrypi:~ $ apachectl -S
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:80                   127.0.1.1 (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Main DocumentRoot: "/var/www/html"
Main ErrorLog: "/var/log/apache2/error.log"
Mutex default: dir="/var/run/apache2/" mechanism=default
Mutex mpm-accept: using_defaults
Mutex watchdog-callback: using_defaults
PidFile: "/var/run/apache2/apache2.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33 not_used
Group: name="www-data" id=33 not_used
pi@raspberrypi:~ $
i jescze screen z winscp:
@ethanak jesli wpiszę w pasek adresu pi/style.css to wyświetla mi tą "wadliwą" zawartość css, a nie tą którą widzę jak otworzę plik w winscp...wtf?
a jak w konsoli wpiszę sudo nano /home/pi/html/style.css to jest ten prawidłowy plik css....WTF???
Wiesz - trudno nie mając dostępu do kompa mi coś powiedzieć. Mogę sobie co najwyżej gdybać (np. czy zrestartowałeś Apacza po edycji tego pliku? Ale pewnie tak jeśli miałeś problem z phpmyadminem).
Przede wszystkim (aby się upewnić): wejdź tam inną przeglądarką, albo chromem w trybie incognito, zobacz czy będzie to samo. Przeładuj zawartość strony wyświetlającej błędny css. To wykluczy jakiekolwiek błędy po stronie klienta. Pamiętaj, że Chrome jest mądrzejszy od użytkownika i lepiej wie kiedy ma ciągnąć zawartość z cache 😉
Czy na serwerze gdziekolwiek masz starą zawartość pliku css?
Edytowano przez ethanak
Już wchodziłem z telefonu, to samo..., przeładowywałem....
nie mam, przeszukałem wszystkie katalogi....
spójrz jeszcze na mój poprzedni post bo go edytowałem....
Głupi pomysł... ale zmień w pliku konfiguracyjnym /home/pi/html np. na /home/pi/gdziekolwiek (na jakiś pusty katalog) i zrestartuj Apacza. Zobaczymy co pokaże.
Pomysł może i głupi ale po dodaniu w home/pi/ katalogu empty i przekierowaniu na ten katalog w ustawieniach apache strona wyświetla się prawidłowo a pi/style.css pokazuje dobry plik...
WTF?
zapomniałem apacza zrestartować... ale działa bez restartu...
Nie wiem. Nie rozumiem. To magia (czarna zresztą). Ktoś rzucił urok na malinkę... zrób jej najlepiej pełny reboot bo może coś się źle skonfigurowało... Ja idę się napić piwa, może jak się napiję to coś zrozumiem... 😞
Czarna magia, przed restartem działało, po restarcie apacza nic nie wyswietlało, ani strony ani pliku css, zmieniłem konfigurację apacha znowu na home/pi/html....
teraz strona wyswietla się z nowym plikiem css czyli ok, ale zmiany w tym pliku nie powodują zmian w na stronie po odświeżeniu... choć pi/style.css zmiany zauważa...
Włączyłem firefoxa, wyłączyłem cache i działa i w firefoxie i w chrome też teraz... modyfikuję css i na stronie widac efekty....
Hej,
Dnia 30.12.2018 o 00:52, SOYER napisał:
Jakiś serwer na RPi, wysyłanie na niego danych, magazynowanie danych historycznych
Jednak jakby ktoś podpowiedział jak zacząć, jak to nadgryźć, dobrze pokierował.... To może pomału, pomalutku...;-)
a 5 stycznia @Trekernapisał :Nie rozwiążesz tego w jeden wieczór.:-))
Jednak potem pojawił się ON, najpierw nieśmiało, coś podpowiadał, na coś zwrócił uwagę, gdzieś użądlił.... @ethanak!!!!!
Dzisiaj udało mi się podpiąć wreszcie moje arduino mega do serwera na RPi (ESP z PMS5003 podpięte od dwóch dni). STRONA DZIAŁA:-)
Jaszne, że jeszcze wiele roboty przede mną, poprawa, a może całkowita przebudowa wyglądu, a że apetyt rośnie w miare jedzenia to może jakieś wykresy, dane historyczne itp...
Jednak to co chciałem zrobić czyli strona internetowa pobierająca i wyświetlająca dane z serwera na RPi gdzie są wysylane przez uC, działa!!
25 stron na Forbocie, mnóstwo postów, pomoc forumowiczów, ale przede wszystkim ogromne zaangażowanie oraz cierpliwość kolegi @ethanak , za które ogromnie dziękuję!!!:-))
Pracujemy dalej, najważniejsze teraz to zewnętrzne IP, w tym tygodniu sprawa się powinna wyjaśnić, potem od razu zabezpieczenia serwera i dalsze rozwijanie strony, respnsywność, wykresy, może podstrony...
Dziękuję,  proszę o jeszcze...;-)
Strona z wyświetlaniem aktualnych wartości z czujników:
