Robocik jeżdżący - kręci się w koło - brak reakcji na czujnik
ma tym timerem załączać pilota i usprawnić program.
#include <Servo.h>
#include <interrupts.h>
Servo dservo;
#define trig 2
#define echo 3
int pwmMotorA=6;
int InMotorA1=5;
int InMotorA2=4;
int pwmMotorB=11;
int InMotorB1=10;
int InMotorB2=9;
volatile int IRpin=7;
volatile int stan=0;
int pos = 0;
volatile int imp=50;
volatile boolean x=0;
volatile boolean pil=0;
void setup () {
   TCCR1A |= (1<<WGM12); //tryb CTC
   TCCR1B |= (1<<CS12) | (1<<CS10);  //prescaler 1024
   TIMSK1 |= (1<<OCIE1A) | (1<<OCIE1B);
   OCR1A = 65530;
   OCR1B = 65530;
 dservo.attach(13);
 pinMode(pwmMotorA, OUTPUT);
 pinMode(pwmMotorB, OUTPUT);
 pinMode(InMotorA1, OUTPUT);
 pinMode(InMotorA2, OUTPUT);
 pinMode(InMotorB1, OUTPUT);
 pinMode(InMotorB2, OUTPUT);
 pinMode (trig, OUTPUT);
 pinMode (echo, INPUT);
 sei();
ISR(TIMER1_COMPB_vect){
if(imp>50){
   pil=1;
imp++;
if(imp>60){imp=51;}
void loop () {
x=!x;
digitalWrite(1, x);
delay(300);
 if(stan==1){
   int duration, distance;
   digitalWrite( trig, LOW);
   delayMicroseconds (2);
   digitalWrite (trig, HIGH);
   delayMicroseconds(10);
   digitalWrite (trig, LOW);
   duration = pulseIn(echo, HIGH);
   distance = (duration/2) / 29.1;
   if (distance<=30 && distance >=10 ) {
     analogWrite(pwmMotorA,255);
     analogWrite(pwmMotorB,0);
     digitalWrite(InMotorA1, LOW);
     digitalWrite(InMotorA2, HIGH);
     digitalWrite(InMotorB1, LOW);
     digitalWrite(InMotorB2, LOW);
     //Ustawienie prędkości obrotowej na 50% (zakres PWM: 8bitów czyli 0-255)
   if (distance <10) {
     analogWrite(pwmMotorB,255);
     digitalWrite(InMotorA1, HIGH);
     digitalWrite(InMotorA2, LOW);
     digitalWrite(InMotorB1, HIGH);
//      for(pos = 0; pos < 180; pos +=1)
//        dservo.write(pos);
//        delay(20);
//      for (pos = 180; pos>=1; pos-=1)
//        delay(20);
//      for (pos = 1; pos < 90; pos +=1)
//        delay(20);
   if(distance>30){
     digitalWrite(InMotorB2, HIGH);
 if(stan==0){
     analogWrite(pwmMotorA,0);
void pilot() {
 if (digitalRead(IRpin) ==LOW && pil==1){
   switch(stan){
     case 0:
       stan=1;
       break;
     case 1:
       stan=0;
       break;
   imp=0;
   pil=0;
Ten timer niby działa ale nie do końca. Świeci dioda jak ją ustwię na wyjście ale już nie miga dopiero jak w pętlę loop wrzucę to miga z delayem a tego nie chce tylko z timera sterować.
Dalej jest problem taki że vector w nim ustwiłem na COMPB ,gdyż na COMPA wyskakiwał błąd że VECT___17 jest w błędzie z dservo . Nie wiem czy to nie ma problemu z pwm od silnika czy to nie zajmuje w procku vectora i przez to się gubi ?
Dalej problem jak wgram bez timerów to jakiej funkcji bym nie wykonał to działa ale tylko na jednym czujniku lub serwie bądź pilocie a połączyć tego się nie dało gdyż program złe komendy dawał . Było if if else i odnośnik do pilota void pilot na końcu loop, ale to nie dawało rady. Potem postanowiłem dodać serwo i już całkowicie zgłupiał. No i ten pilot jakoś nie chce normalnie działać na załączeniu ze stanu LOW a na odbiorniku IR jest ciągle 5v czyli HIGH a jak pilotem załącze to 4,5 czyli powinno LOW złapać , a się gubi i nie chce.
W programie jest pokazane jak co się ma dziać i tak bym chciał aby to działało tylko nie chce.
No ok, ale aby to przerwanie ruszyło to timer musi odliczyć ileś tam impulsów, a u ciebie nie jest on skonfigurowany poprawnie.
Jak ilość impulsów zliczonych przez timer zrówna się z tym co podałeś w rejestrze w tym przypadku OCR wtedy nastąpi wywołanie przerwania. Samo sei() tylko zezwala na akcję wywołania przerwania.
#include <Servo.h>
Servo dservo;
#define trig 2
#define echo 3
int pwmMotorA=6;
int InMotorA1=5;
int InMotorA2=4;
int pwmMotorB=11;
int InMotorB1=10;
int InMotorB2=9;
int pos = 0;
void setup () {
   TCCR3B |= 0;
   TCCR3B |= (1<<CS32) | (1<<CS30);  //prescaler 256
   TIMSK3 |= (1<<TOIE3);
 dservo.attach(13);
 sei();
ISR(TIMER3_OVF_vect){
if(imp>50){
   pil=1;
imp++;
if(imp>60){imp=51;}
x=!x;
digitalWrite(1, x);
void loop () {
pilot();
 if(stan==1){
   if (distance <10) {
//        delay(20);
//        delay(20);
//        delay(20);
   if(distance>30){
 if(stan==0){
void pilot() {
   switch(stan){
     case 0:
       stan=1;
       break;
     case 1:
       stan=0;
       break;
   imp=0;
   pil=0;
Jeszcze timer 3 próbowałem tak skonfigurować .
Też ten sam problem . Czyli co źle dalej skonfigurowany ? Gdzie mam to sei dać ?
Jaka jest instrukcja zmieniająca stan diody na przeciwny w tym arduino - pisze program testowy ?
Jakie taktowanie atmegi masz ustawione ?
Dioda powinna migać co sekundę - program testowy
Wzór na OCR:
OCR = (F_CPU/PRESKALER/CZESTOTLIWOSC) -1
15624 = (16000000/1024/1Hz) - 1
    #include <Servo.h>
   void setup () {
       TIMSK1 |= (1<<OCIE1B);
       OCR1B = 15624; //1 Hz przy 16Mhz (zegar)
     sei();
pinMode(1, OUTPUT);
   x=!x;
digitalwrite(1,x) ;
   void loop () {}
sketch_may14a.ino: In function 'void __vector_18()':
sketch_may14a:19: error: expected `;' before 'digitalwrite'
Wyskakuje taki błąd przy wgraniu Twojego programu.
Więc tak dioda na pinie 1 załączona jest i nie widzę aby jakieś przerwania miała , chyba że to powyżej 50 Hz jest .
Zamiast
x=!x
daj
x=^x
albo tak
x^=x
A wzór na OCR podany kilka postów wcześniej to co ?
teraz dioda zaczęła chodzić jeszcze na tym 1 programie
miga co 5 sekund na 1 sekunde.
Czy normalne jest to, że jak podepnę zasilacz 12 v pod to arduino to powinno takie niskie dźwięki wydawać takie piszczenie ? Pytam bo tak mam. W Instrukcji było że od 6 v - 20 v można zasilić.
Te xor ^= nie działają. Tylko to =! działa ale jak mówię miga co 5 sekund na 1 sekunde
 #include <Servo.h>
Servo dservo;
#define trig 2
#define echo 3
int pwmMotorA=6;
int InMotorA1=5;
int InMotorA2=4;
int pwmMotorB=11;
int InMotorB1=10;
int InMotorB2=9;
int pos = 0;
void setup () {
   OCR1A = 65530;
   OCR1B = 65530;
 dservo.attach(13);
 sei();
 pinMode(1, OUTPUT);
//if(imp>50){
//    pil=1;
//imp++;
//if(imp>60){imp=51;}
x=!x;
digitalWrite(1, x);
void loop () {
 if(stan==1){
   if (distance <10) {
//        delay(20);
//        delay(20);
//        delay(20);
   if(distance>30){
 if(stan==0){
void pilot() {
   switch(stan){
     case 0:
       stan=1;
       break;
     case 1:
       stan=0;
       break;
   imp=0;
   pil=0;
A jak ma migac ?
W przerwaniu nie może być dealaya ani sei, ani cli
Poprawiłem. Czy tak jak teraz jest dobrze ?
I czy obsługa pilota jest poprawna ?
Po wgraniu tego programu dioda ciągle się pali nie wiedzę aby przerywała. Ustawiłem OCR1B = 15624; czyli powinna co sekundę migać ale nie miga w tym głównym programie. Nawet co 5 sekund nie miga tak jak to bez pozostałych parametrów kodu robiło.
